1987 Merc 4cyl I/o Throttle Stuck
frreddi
MY THROTTLE goes forward fine but cant get it to go in reverse any suggestions???
RJLeuwen
Re: 1987 Merc 4cyl I/o Throttle Stuck
Sounds like you may have a broken lower shift cable. When was the last time it was replaced?
RJ
frreddi
only had boat 2 years dont know how old it is
wkb2460
Disconnect the shift cable at the engine and try to move the shifter,
If it moves fine your problem is with the cable from the engine to the outdrive.
