Re: 1977 35 hp johnson
Very easy to tell if your motor has been retrofitted with a tell tale. Remove the cowl and look to the rear starboard corner of the lower cowl. Is there a black rubber hose running from the block to a 'nipple' in the lower cowl? If so, then yes, you have a tell tale. If it is not functioning, there is a restriction in the cooling circuit, the water pump is not functioning, little critters may have built a nest in the nipple and/or water line, restriction in the water intake area, etc...
