I had a little problem today and I hope somewhat can help point me in the right direction. My little 4hp has been great. I was in a busy channel today and I loaded up with weeds. I shut the motor off, cleared the weeds and placed her back down. I had drifted a bit and was in a bad spot. I got a little anxious. I started the motor and threw it into gear very quickly. So quickly that I didn't back down the throttle. You guessed it. Something must have broken because she wouldn't go into gear from that point on. Once I got home, I pulled the prop and the pin is still in tact and looks good. I suspect I caused some damage somewhere in the lower unit. Any idea where I should start?
Thanks
Thanks
