BlueBombNut
- Jun 16, 2008
- 33
my 35 hp Johnson (1980) is not getting fuel to the pistons, I am waiting for my manual to arrive but hope to gain some insight while I wait. Does anyone have a fuel diagram post carb? I have rebuilt the card, new gas and new plugs. I only thumb tested for compression and with out numbers I think there is enough to draw the gas from the carbs. I will be getting a compression gauge tomorrow to verify. When I look in where the carb hooks up I can see what look like reed valves, when I hand turn the flywheel I can see them flutter just a bit. Could these be the causing my issue? better ? what are these called, they look to be part of a plate held onto the block with a phillips head screw right in the center if you look through the opening where the carb hooks up.
Much too long for a post but just wanted to give as much info as I had available.
Much appreciated.
Much appreciated.
