Greetings, I recently purchased a 2001 (I think) Yamaha 90 HP outboard. As I was going through it I noticed two things that I don't understand. First, there is a small diamater tube that runs from the boatside of the lower unit up over the hydraylic tilt motor and cylinders and comes out near the steering tube on the front of the engine and is plugged off. The tube has been smashed (improper routing?) in the hydraulic cylinder area. Upon removing the lower unit plugs quite a bit of water escaped out the lower hole. Baring a pressure test, is there any possibility the water could have entered through the broken tube (it is broken below the water line). Also, on the left side of the cylinder head (standing at the rear and looking forward) there is a brass bolt with a hollow center it a position where a head bolt would go. The hollow center drips a drop of water every minute or so when I am running the engine on the hose in the driveway. Any ideas what this is and how I can fix the drip? I am assuming it may be a receptor for a temperature sensor that stayed with the old boat.
Many thanks,
Thomas
Many thanks,
Thomas
