kenmyfam
- Aug 10, 2006
- 14,397
Re: Trailering and overdrive
Thanks for the input. I will check it out again and let you know.
Ken.
You definitely have torque converter lockup in direct. There apparently was not enough load on the engine to make a difference. Try it again on a grade. If that doesn't work for you, let the tranny shift into third with the shifter in "3". At about 50 mph gradually press on the gas while watching the tach. At some point you will feel what appears to be a downshift. That is not a shift into second. That is the converter unlocking. Believe me, at 50 MPH you will know the difference between a 3rd to 2nd shift and a 3rd locked to 3rd unlocked. Even in town on a 35 -40 mph street in third you can watch the tach drop as the converter clutch engages.
Ken.
