Trailer lights
Black Beauty
I have a 2007 Karavan trailer that the lights are not working correctly. The brake lights and blinkers work great but the driving lights will not come on, any ideas?
kenmyfam
Re: Trailer lights
Welcome to iboats. Summising that the bulbs are O.K. and fuses.
Sounds like the ground is O.K. if the brake and flashers are working. Have you checked that the tow vehicle is not the cause yet ??? You can get a cheap tester that just plugs into the tow vehicle and will confirm or otherwise that it is O.K. to there. Verify that and we can go from there.
Re: Trailer lights
Hey BB... check the fuses in your vehicle. I had the same problem not even a month ago with my Karavan trailer and it ended up being that my tow fuse in my Nissan Titan had blown. Replaced it and it worked just fine. Now I'm onto a whole other mess of problems. :)
Good luck!!
mikeyc
