Crestliner Drainage ???
BULLWARKS
Hi,
I use my 1850SF to fish, in the heat, cold, wind, sun and RAIN. My wife and dog like to sit in the boat and relax (except in the cold & wind). Problem is that with the bimini up and side curatins on water runs off the top and pools on the floor in the passageway between the dual consoles to the bow and eventually runs into the enclosed area soaking it.
Has anybody solved this? Can I install a floor drain? What's under the floor there? Will water move to the bilge from there if I can put the drain there?
I know, lots of questions.
tashasdaddy
Re: Crestliner Drainage ???
when i've been redoing decks, i have put a shower drain in the bow area of bow riders, and a pvc pipe to the bilge. have no idea how your boat is constructed under the deck.
redfury
My Glastron has drainage from the bow area that goes through a pipe and out the side of the boat. Depending on where the floor of the area the water drains to is in relation to the water table, you can let it just flow right out the side of the boat. Otherwise, I'd run it to the bilge.
