A alarm will not shut off with the key in the normal position . Engine seems to be getting oil (blue smoke ,level going down in tank ) If I move the key back toward the off position and hold it in the in between position the motor will keep running and the alarm goes off .Tank is full of oil .I don't know if it is a key problem or a oil level sensor problem , or a heat , heat sensor problem , alarm comes on as soon as the key is moved in the on position ,a constant beep any way to test? Also pumping water find does not appear to be overheating I believe the engine is a 94 the serial # is OD076647 Any help would be appreciated
