Re: Evinrude Fastwin Fuel Connection
Wow, just when ya think you've seen it all. Can you post a picture of the other side without the cowl? That's where people typically locate a fuel pump on a converted motor. If it has been converted and, then I think you are better off going to an omc dealer and buying a standard omc fuel fitting - not sure of the part number. and replacing the rigging ya got going on there. After you sort out your fuel line connections and hosing, you can but a standard tank with a modern fuel connector. The hose will have a bulb, which after opening the vent on the cap, you'll squeeze it till it's firm. If ya want to convert it back to a 2 line tank, you'll need a manual with decent parts diagrams. And I have used 2 line tanks for years with no probs, so don't be afraid to go that route either.
