Mercury 175XR2 Sportjet
TysonG
Hopefully I am posting this in the right area. If not please direct me to the appropriate forum.
I have a Mercury Optimax Sportjet. For the past 3 weeks I have had the low oil warning going off. There was still smoke when I started it up and both oil tanks are full. I assumed the oil level sensor was bad and so did the mechanic so we replaced the sensor. I took it out yesterday and ran for about five minutes, shut it off and then started it again. When I started it the second time the alarm went off again. I am now concerned as there is minimal smoke when starting it (about as much smoke you get from exhaling a cigarette). Could this be the module that is bad? How can I cut off the oil injection system and mix the oil myself? is this ok to do until I get to the root of the problem?
Thanks in advance for any help with this!
CraigC
Re: Mercury 175XR2 Sportjet
Anytime you question the oil injection it's good insurance to run premix in it, it's cheap insurance until you get to the root of the problem!
Honestly - I'm not real familiar with the Opti's oil injection system - so I'm sorry that I can't be of more help with it...I just think no info from me is better then bad info from me!
I'm familiar with the carb models oil injection, but I believe the Opti's are very different.
Someone else should weigh in here soon I'd think.
TysonG
yeah i just word on another forum that adding oil straight to the gasoline in the optimax can gum everything up. thanks for taking a swing at it tho.
If i am getting smoke when I start it up, i should feel comfortable that I am getting oil, right?
CraigC
yes, if you get smoke you're getting oil.
CraigC
Depending on what year that Opti is this seems to be a fairly common thing with some of them. I don't remember where I read about it, but if you google it you should find some more info.
dart69gts
Hi ` i`m also new to the post . i have a similar problem . I bought a 1997
searay jetboat with a 175 h.p. mercury . the guy told me that one day
he made a sharp turn and the low oil alarm started beeping . he said the tanks were about 1/4 full when it happened. ever since it happened it keeps beeping on and of . but the boat seems to run fine. he said he checked with a mechanic and they said the alarm needs to be reset does that sound right ? can the alarms be reset ?
