I have a newly re-built starter, new battery, new solenoid and battery cables.
I've taken the starter back to the re-build shop and they can't find anything wrong with it.
80% or more the motor turns over easily, starts and runs good.
Some starts, the starter will engage the flywheel and strain to turn it very slowly or not at all.
If I try to turn the flywheel by hand or use a pull chord on the flywheel it is very difficult to turn or not at all.
Eventually, after a dozen attempts with engaging the starter, it will begin to slowly turnover and start as normal.
Could there be pressure build-up in the cylinders that isn't releasing?
Any help would be appreciated.
