thereistand
- Jul 1, 2008
- 5
I need some input... I purchased a used pontoon boat last week. It is a 16ft with a Johnson 48 hp (1988 model). Took the boat out on the lake. The engine ran great, very smooth. I ran the boat about an hour before I started to hear an unusual sound coming from the engine. The sound was only present while the motor was in gear (a mild consistent clanking or slapping sound). The sound would get worse at higher RPMs. I immediately went back to the boat ramp (about 10-mins away) and trailered the boat. Once back home I pulled the dope plug on the lower unit. A white milky liquid poured out. Yep, water in oil. I called around to a few dealers. I was told (3) different things: 1) "Water in lower unit and making a sound" - "the lower unit is 100% bad". Will have to replace (he wanted to sell me one installed for $1150.00. Another dealer: "water in oil and making a sound could be corrected by changing the dope and replacing the seals" - "sound might go away". Third dealer: "Bring it in, can-not tell you anything without looking at it" (to me the third dealer got it right, I know someone needs to look at the unit before diagnosing). I know I need to take it in somewhere, as I am not a boat mechanic. However can anyone tell me if I need to start looking for a good used lower unit, or can a service and re-seal fix the problem? Would the break down of the dope cause the noise by itself? Or has something broke or worn to the point that changing the dope would not correct?
Thanks for any advise.
