how to tell what year
byr0n
Is it possible to tell the year from the serial and model number of the inboard motor and leg ?
jerryjerry05
Re: how to tell what year
Year of what? More info_On the transom should be a group of letters and #s.That should have the year included in it.Usually the last 2 or three will have the year. Jerry
Ayuh,....
The Boat's year can be ID'ed as Jerry says,....
As for the Motor,+ Drive,..??..?? Who's is it,..??..??
byr0n
According to the info i have on this boat it is a 1979 Campion, i can not find a serial number on this boat i have talked to Campion they said it was not uncommon for them to have hidden the serial number underneath the trim and have dismantle part to get at it, The motor is an OMC Model 980703 Serial W67219
Thanks
Ayuh,....
4 cylinder,..??
6 cylinder,..??
V8,..??
A 1979 would be a Stringer Drive,....
Good Luck,..... You need it,......
byr0n
has a Ford 302 8 cyl
And why do i need luck??
79Glastron
What Bond-o means is you better have a thick wallet, parts can be expensive compared to a merc or volvo. Its an out dated drive....bottom line.
thumpar
That is if you can find the parts.
79Glastron
If you know where to look its not that hard.
