John Birge
- Jun 30, 2008
- 4
I have a 1992 Mariner 40 Magnum which I recently got from a family member. I have cleaned the carbs and replaced numerous gaskets and the initial test run went great. I disengaged the oil warning (beep that occured on startup) because I thought the sensor was bad. The initial test run went well (about 30 minutes). The second run did not go as well. About thirty miunutes into the ride the alarm went off(loud steady indicationg and oil issue). The oil res. was full. I cut the motor off and waited about thirty minutes. When I restarted the engine would idle (water was running) but when I engaged the prop it shut off. After a tow to the ramp everything started fine and I got it back on the trailer. Any ideas?
