mercury 200 xl oil problem helppp !
crager
1995 mercury 200 xl problem just started when boat sits for a day i get injection oil in my fuel line and it prevents it from starting i then have to disconnect it and pump out about a quart of oil then it will run fine i dont want to do this every day ??
j_martin
Re: mercury 200 xl oil problem helppp !
There's a "fitting" on the motor that goes into the crankcase and supplies pressure to the remote oil tank. It's a combination check valve and let off valve. It isn't letting off, and keeping the system presurized when shut off. It should normally let the air off the remote oil tank in a couple of minutes after shut off.
That part's your problem.
Hope it helps
John
