Andy in NY
- Oct 25, 2007
- 2,109
Okay, I am going to put this all out front. When I bought this boat back in october, I was waaaaay too excited about getting a boat that I did NOT check things out as well as I should have. When I looked at it, I walked around on the deck checking for soft spots. That was all good. Bought a motor for it and was on the water.
Then I noticed that in the middle of the boat where 2 sheets of decking meet one was higher than the other by about an eigth of an inch.
Then, once up to speed I noticed that the seat had some movement (can feel the deck underneath moving).
Then, a few days ago I decided to lay on the groung and look under the boat.
So, it all makes sense now.
I have been having issues with the motor sitting too low and creating some wicked rooster tails, as well as making the boat REALLY sluggish. Well, knowing this now my money is on the fact that the foam is all saturated.
What it looks like to me is that it is actually from the trailer. In the 4th pic, you can see the roller. It is hard, like some kind of wood or hard plastic or something. So, I have decided that I am going to patch the fiberglass and keep using it for the rest of the season, but on a limited basis... just going to and from the sand bar (which is about a 1/2 mile from the launch) and not going out on the lake cruising.
At the end of the season the deck will come up for inspection. If it is just in need of new foam, deck and fiberglass repair I am okay. If stringers and transom are needed, well I just don't know. I have read through many many projects where people do them, but I doubt my ability to do it.
First things first.
1)what do I need to do to patch the fiberglass?
2) what do I do to correct the rollers?
First things first.
