Does anyone know what would cause a significant fuel pump whine in the high pressure fuel pump on the 2001 5.7L GXI Glastron 205? If I jumper to apply power to the pump I can get the whine to temporarily go away by reversing the pump. If I purge the system by opening a pressure release on the pressure guage and allowing the fuel to be pumped into a fuel can there is no whine. If I run the engine at an idle after this purge there is no whine but after running the engine under load for several minutes the whine comes back. I believe the low pressure pump may be out, making the high pressure pump work harder, but I am not sure. When I run the engine, the low pressure pump has approx. 4psi of pressure and the high pressure pump is at approx 30 psi. As soon as I shut off the engine the pressure at both pumps drops to zero. Volvo sells only the fuel cell as a complete unit for $900.00 (which consists of both pumps and the filter), I would like to isolate the problem before I invest in any parts. I heard it could be picking up air in the fuel lines before the pumps and fuel cell. Need help please advise. Thanks
