1988 14hp SPL - Cooling Water Discharge
oozamalak
I have a 1988 14 hp Evinrude that has not been started in a year.
Could someone answer this question for me?
I cannot remember if the discharge for the cooling water is on the back left corner of the motor, looking from the front of the motor, or if the motor eliminates the used cooling water from the motor via the large port on half way up the shaft of the motor.
I have had the carb and fuel pump rebuilt and the plugs have good spark, but the motor is still difficult to start. Any suggestions on what to look at next?
Thanks
clemsonfor
Re: 1988 14hp SPL - Cooling Water Discharge
just look uder the top of the hood for the nipple? Or open the cover and look for the hose that exits throught he lower engine cowl?
-nate
tashasdaddy
are you using new gas?
oozamalak
New gas on Thursday and the engine fired on Thursday evening. Took boat to the lake and tried on Friday and Saturday and all I have to show for it is a raw spot on my finger:confused:
Found the nipple thanks. That is were my memory of the exit was located.
