I have a 1986 75 HP 4 Cylinder Merc. The motor does not idel well and dies when I try to drive forward. If I choke the motor quick every 5-8 seconds the motor runs pretty good. As soon as I get up to about half throttle, the engine will take off without me choking it.
I turned up the idel with the two idel screws on the intake faceplate. It is ideling way to fast (estimated 1500 rpms), but atleast the motor does not die all anymore. It does still die quite often while cold and every once in a while while warm.
Compression is 120 PSI on all 4 cylinders with a brand new gauge. All 4 cylinders are firing. I'll be replacing the spark plugs next weekend.
Any ideas on what is wrong and what I should do next?
I was going to order carb repare kits for the motor on here, but I can't find the right HP, year, and number of cylinders. The carb rebuild kits I find are for 3 cylinder motors.
Any thoughts on what I should do next? What about where to buy a carb rebuild kit?
Thanks
Thanks
