I have a 1968 Johnson 100 that starts and runs beautifully only to die in the middle of the lake at mid to full throttle--as in no spark. After trying to start it in vain for half an hour, it started again after wiping the plugs, but they were only wet, not fouled. I have read that this is probably a pulse pack issue, but if you have any thoughts otherwise, please send them along.
My uncle from whom I got the boat has replaced one after another pulse pack over the years and the one that's on it is supposedly new--but unused for 15 years. I rewired the whole motor because every single wire had corrosion under the insulation and in the process cut out the diaphram/kill switch and the "thermo switch"--so they're not the problem.
I'm not in the mood to replace the expensive pulse pack only to have it go bad again, so I'm wondering if anyone has a schematic diagram of the pulse pack that I could use to troubleshoot (or build my own). Or better yet, does anyone know how I could use a car setup on this motor? An old Subaru I owned had a distributorless ignition that uses a reluctor to generate a pulse (much like the Johnson's sensor). Couldn't this pulse then be sent though a car coil and then through the distributor? Unfortunately, I don't know enough about boat or car systems to figure this out myself. I'm just surprised that I can't find anyone who has already done it.
Thanks,
JustinJ
Thanks,
JustinJ
