When I first start out cold it seems to run and start fine but when you go to take off is when you notice you are low on power. At first it was like running on 2 or 3 cylinders until you go wide open for about 300 yards then like flipping a switch, FULL Power kicked in. it was like this for about 6 tanks of gas. Now you can drive all around the lake on 2 or 3 cylinders then stop the motor for 3 to 5 minutes restart and will run good the rest of the day. Only once just recently did it cut out for about 5 seconds while driving after warm up.
