thermastat cant be found? help me?
licketdsplit756
j140txccm ser_g7743284 do i need to pull the plastic casing apart to get to where the therm is at. internet shows no therms for a 1988 140 hp johnson was i told the wrong yr. these therms are like plastic cones screwed into a plate with a rubber gasket? please help me locate them # on them is 08lu.?
HighTrim
Re: thermastat cant be found? help me?
You will need to pull the thermostat cover to access them on the cylinder head. T stat assembly part number 0434137, vernatherm part number 0394411, Tstat cup part number 0330273, DIAPHRAGM part number 0394408 and the spring of course too.
Vic.S
Parts 94, 95, 96 etc in the attached picture
licketdsplit756
all understood i have the therms in front of me do i have to take the plastic cones apart? it looks like a full assembly item all cased into one unit?need more details?
mikesea
it will unscrew ,heres the link to your part on this website,support the site when u canhttp://www.iboats.com/Johnson_Vernatherms/dm/*******.100129946--category_id.271266--list_time.1216826540--**********.375562623--view_id.271286
