Hey Rodbolt, I have found a lot of info that you have posted on this subject but not specific to my issue. I have a pair of early 90's(1991 in think) 130 Yamahas. The oil injection system was removed some time ago by a previous owner. Well this summer I have been getting alarm and RPM reduction I assume from an oil issue(Water temps are fine and I have replaced sensors). This is on the port motor. The problem is intermitten. The wiring on the Tachs have been altered so that they read full oil (the arrow is over the full oil symbol).
The problem had gotten so bad about three weeks ago that i could not use the boat. I started tracing wires from the old oil plugs still on the motor and found the only one that went to the computer(black box on back of motor with coils) was a yellow wire. I figured this was the wire that sent signal to the computer to shut down. Cut and capped the wire up by computer and the problem was gone.......until yesterday I got it twice. DAMN! As soon as I bring RPMs back down the alarm goes out I can bring motor up to speed again.
The plug on tank side of motor has the following wires - blue, black, brown,yellow, green/red, yellow/red, green/black.
Two plugs on the other side of motor has the following wires:
BLACK PLUG- brown, blue, red/black and black
GREEN PLUG - yellow, yellow/red, green/black. green/red
The two harnesses that go into the computer on back of the motor have the following wires-
Bigger harness- brown, black, yellow(the one I cut), pink, white, green, grey/black, blue/red
Smaller harness that comes from other side black box into the back computer - white/green, white/black, white/red, and white/ yellow
Do you have any ideas what could be causing this? I'm at a loss now. Thought I had the problem solved!! I had a inboard Mako for years....could just about rebuild that old 351 Ford with my eyes shut. I'm new to outboards dont have any experience with them! Thanks for your time.... I'll take any ideas or suggestions you have!! Mike
