Re: 93 Johnson 70TLETS water pressure
First, is it overheating? Can you touch the cylinder head(s) w/o getting burned after motor has run for a while?
Are you saying pressure was 15 psig before the rebuild and now is 7 psig? If pressure after is lower, you got something wacked (gasket, outlet grommet, etc.).
Did you replace the pump liner and wear plate?
Help us w/ some info .....
