My motor will start with the electric start (too hard to start for rope) and will run if you rev it way up but will die right away if you back off the throttle. This is with the hose and the ear muff things.
I have verified the compression to be equal in both cylindars around 90 to 100 PSI if I remember correctly. I also rebuilt the carb a year ago and it ran great. I tanked the carb anyway and blew it out with compressed air. The float is level. I removed the fuel line and pulled the rope and the fuel pump squirted gas. I replaced the power pack. What could be going on with this motor. Should I change the sensor, or the ignition coils?
Should I throw it out and buy a different motor? I am pretty sick of fooling with it but maybe yall can help. I have a manual also.
Mike
Mike
