Battery charging with 1986 Evinrude 40HP
ncobb
Hi,
I have recently purchased a 14'McKee Craft Aruba with an '86 Evinrude 40 HP engine; the model is E40EL CD. It originally had oil injection, but that has been by-passed. The engine does not have trim/tilt. My question is this, "Does this engine charge the battery when running?" There is no ammeter/voltmeter instrumentation.
Any help would be appreciated.
ncobb
Rabun Gap, GA
tashasdaddy
Re: Battery charging with 1986 Evinrude 40HP
it charges enough to maintain the starting battery. if you are planning on a lot of electronics, lights radio, trooling motor, you need to buy a deep cycle battery to run the accessories. be sure you have a rope to start the motor is you elect not to use the second battery.
ncobb
Thanks Tashasdaddy,
I thought that was the case. I plan on adding a deep cycle battery and a battery selector switch. I will be using a depth finder and trolling motor which I will run off of the deep cycle battery.
I appreciate the assistance,
ncobb
washind
You might also consider a small solar trickle charger (works well for me).
ncobb
Thanks washind,
That's a really good idea.
ncobb
