tparker6998
- Aug 2, 2008
- 2
Hey guys I just recently got a boat that has a 1980 Johnson 25 seahorse. It is tiller steer with an electric starter and a pull start. I haven't put it in the water yet because it sat for about three years. I have run it in a tub of water and my buddy says that it "pees" when it is in gear but I don't see anything coming from the outlet on the side of the head. Should I go ahead and drop the lower unit, and replace the water pump and gaskets? Also does this motor charge the battery as it is running or do I need to charge it before and after each use? any help would be greatly appreciated. Thanks in advance.
