Tow capacity help
zach103
I need help finding the tow capacity of a 97 ford ranger splash.. . 2.3l 4 cyl .
ive searched google and still cant find it
JB
Re: Tow capacity help
I assume it is a 5 speed. . .?
It isn't going to be much. I would guess 1500 to 2000#.
Ask Ford. Give them the VIN and they can look it up.
zach103
enough to tow the boat? iboats says mine only weighs 1250
zach103
im not sure if its a 5 speed.. i believe so.. ill find out more info when my dad calls the guy
ferrellb
Trailerboats.com lists tow capacity at 2000 lbs and requires auto tranny to tow.
25thmustang
Probably at the max for the truck but it could tow it.
I'm also located in Berlin CT.
ebry710
Ensign
Where your truck might have a problem is if the ramp is steep and ungrooved and your tires are stock (like the old Firestones Ford use to use). The Ranger is light in the back and sometime requires a little weight (like a buddy or a piece of concrete) to keep the tires from spinning up a steep, wet ramp.
reelfishin
I use a 1994 2.3L 5 speed two wheel drive Ranger for towing all the time, its fine up to about 2,500 lbs or so but doesn't like to launch anything over about 1,500 due to traction and the tall gears.
