Why dont water come out?
derickmariah
I just put a new water pump in and i still dont have any water coming out the top two holes. I have a evinrude 115 hp motor. When on the water it just spits out a little water through one of the holes but not both and its very very little. When hooked up to a hose the water just comes out the lower end where it is bolted to the upper, what could be wrong?
ebry710
Ensign
Re: Why dont water come out?
Welcome to iboats.
Assuming that the impeller was placed in the right direction and the engine was put together correctly, your problem would be a blockage in the system.
ebry710
Ensign
You have a blockage in the cooling circuit somewhere. Odd that both happened at identical times though. The usual spot when they sit is the tell tale water line, or nipple. Little critters love to build nests in there.
Other than that, you may need to drop the lower, and flush either the garden hose, or compressed air, up the water line, then back flush down, until you have sufficient flow. Also ensure that the water intake area is not full of debris.
I pulled a quote from the question just asked by noelm and answered by HighTrim. I feel it answered your question well. I did know how to direct you to that forum. I hope it helps.
5150abf
Alot of times a motor won't pump on muffs.
Mine always did, changed impellers and it wouldn't, got it to water and it pumped better than ever but I still have a problem on the muffs.
If you can get it to water and see if it really doesn't pump.
The water pumps aren't self priming, the won't suck up water and need to be fully submerged to work.
5150abf
Oh, could be wrong but I think water only comes out the top holes after the thermostat opens.
derickmariah
well i havent had time to check the intake to see if any thing is stuck but ill see what i can do and get back to you and let you know if i find any thing stuck. Its a 1982 evinrude 115 hrp larson boat. Also the motor doesn't get too warm now when i run it but i just dont think its running right. so ill check the above out and report back! thanks for the help!
emdsapmgr
You should have a steady stream of water flowing out of the lower cowling telltale when the engine is running. The telltale shows that you have water pressure to the block, ahead of the thermostats. Generally, a strong telltale stream shows that the impeller is functioning. If you have no telltale, you need find out why-perhaps the cowling nozzle is plugged. In addition to the impeller, you want to be sure the thermostats are functioning properly. They function to let heated water out of the block, back into the midsection. At idle, water droplets will exit the two midsection exhaust relief holes after the thermostats open-usually a minute or so after starting the engine. When you are on plane, two huge streams of water should exit the same two exhaust relief holes. If one or both of the thermostats are stuck open, the engine can run cold, causing running issues, and piston/ring coking problems. You may want to open up the thermostat housing and check the stats and pressure relief valves for proper operation.
