Most models of the 1993 90 and 115 used the gearcase with the two part driveshaft PN 435474. You will need to compare the part numbers between your motor's model number and the donor motor and be sure that they have the same driveshaft. You can easily switch the shift rods. http://epc.brp.com/default.aspx?brands=ej&lang=e
