Re: Need repair in virginia
If you have the "wire rope" and pulley steering system, and the plastic coating on the wire rope is cracked, the wire rope needs to be replaced. The pulleys need to be inspected carefully, and all of the connection fittings to the hull need to be inspected and tightened or replaced.
This type of steering is fine if maintained, but can be dangerous if it breaks.
My whaler still uses a wire rope and pulley system, and its been fine for over 40 years, but the wire rope has been replaced 6 or 7 times, and none of the connection fittings are original, having been replaced by stainless long ago.
If it's a Teleflex single cable type system, ignore everything I just said
