water in engine cover. were is it coming from?
dssranger
i have a 1999 ocean pro 200. when i idle around and trim the motor up no water under the engine cover,when i am on a plane and come off plane and trim the motor up water pours out of a space in the engine gasket which faces the bow and does not have waves getting in there. when i run it on muffs with the cover off no visible water coming from anywhere. help.
kenmyfam
Re: water in engine cover. were is it coming from?
You need to watch it when it is on plane to see if the wash is getting in through the same area that it is coming out.
tashasdaddy
or if you have a leak in the tale tell hose.
kenmyfam
Good point but would it not still leak at idle and trolling speeds although not as much due to the lower RPM ???
tashasdaddy
could be pin hole, that does not show, until the rpms, and pressure gets up.
Dhadley
There are a couple of common things. One is the shift shaft seal may be leaking. The other is if the motor is too low and there's a mist anywhere near the lower pans or the air intake it'll suck the water right in.
