i got a problem
nathan01
I have a 150hp Mercury and the water pump keeps going out on it. What could be the problem?
Thanks Nathan
j_martin
Re: i got a problem
Where are you driving it? Do you ever crank or pop-off the engine without water supplied to it? Are you using good parts?
MIKEY*2007
Re: i got a problem
drop leg turn prop with power drill and see it shaft is bent this will eat up impellar
Laddies
Banned
Re: i got a problem
If the grommets on the water tube that is under the pump base are leaking the pump will suck exhaust and burn the impeller up.
