Have the usual sob story, got used boat guy said it runs "it dont"
turns over fine but no spark. ser#1692302
any help greatly appreciated , wiring diagram would be great too just to make sure all is were its supposed to be.
Thanks.
Taking the magneto apart (not removing the magnet rotor) is simple I would remove the cap and take a look cause it may be just burned/dirty/out of adjustment points and nothing else. Be careful not to forse or break anything. If the points are just a wee bit too wide it wont fire,but if they are right on the money the mag will be "hot" and should throw a strong bright spark 1/2 inch. Of course you need to inspect the rotor /cap etc for cracks but alot of wear often doesnt keep one from sparkin.
THANKS SO MUCH EVERYONE FOR THE HELP.
Found the cap was cracked , points were rusted solid.
off to the parts store i go and then to the lake i hope.
thanks again.
