Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I got my carb rebuild kit today and I'm ready to tackle this adventure!! I have a can of Gumout carb cleaner and a can of compressed air. What should I use to soak the parts in, or is spraying with the Gumout sufficient?
if you dont have any regular parts cleaner you can use gas.
i dont soak mine but i do take a piece of wire pull one strand off and use it to clean out the jets real good ,dont use anything inside the jets that will scratch the insides.
now if i pull one apart that has been sitting for a long time then i will soak them.
It is ok unless you have a seriously gummed up carburetor. Then you need one of the cans of stuff with the dip basket from the auto parts store. That stuff is expensive and not worth it for one casual, not-too-bad carb. The can has to be big enough to submerge the carb. A gallon can for most of them.
