This is a 1984 (I believe but am not sure how to check) 4 cyl evinrude. I started the motor last week and noticed there was a leak but couldnt figure out where it came from.
I took the boat out, the motor ran fine for about an hour, after that I got the buzzer from the control box, the motor would not start for a while but if it did start I was only able to go half speed.
The next time the motor would not start, eventually I got it started and noticed that the power block, (bottom side below the cylynder is heavily spraying water) the motor would run a bit and then die.
What should I do? Scrap the motor? Attempt repairs? Is it a headgasket and a cracked powerhead? I just dont know. Please help.
