I have a 2004 6HP Johnson outboard motor I purchase used about 6 months ago. I have take the boat out 3 times. The first two times it ran fine (maybe a little under powered). It starts right away. This last time the motor seems to be cycling between running fine and wanting to cut off, even at full throtte. I did notice that the priming bulb is pressurized. I can't squeeze it. The boat had been sitting with fuel in the tank for about 6 months before I purchased it. The motor was stored in doors all winter. The oil should have a stablizer in it correct? I have gone about 2/3 of the way thru the old gas/oil mix, replacing it with new fuel. What should I be checking?
Thanks,
Thanks,
