Re: Cant get my 50hp force to plane properly?
Could be lots of suitable props. Post this as a new thread under the prop forum. There are some pros there that can help you. Give them as much info as you can. For instance they will want the hp rating of the boat, your current prop measurements, WOT rpms, total weight, the motor's vertical height in relation to the boat bottom and trim info. Photos of your current set-up won't hurt either.
With that said, the 85 hp will have more push than your 50 hp Force. Something isn't right.
