changing oil mix?
rockyrude
My buddy just picked up a '53 evinrude 5hp, if I remember correctly the mix was 32:1. He told me a mechanic said that with the new oils he could run 50:1 . I think this is a disaster waiting to happen, yes or no?
Vic.S
Re: changing oil mix?
If you look at Chinewalkers article in the Engine FAQs you'll find 24:1 for pre 1960.
JB
Actually, it is 24:1 for pre 1964 OMC engines.
D
DJ
Guest
It is 24:1 but you'll find that if you use a high quality synthetic or synthetic blend it will smoke a lot less.
samo_ott
Evinrude didn't make a 5hp in the 50's. Are you sure of what you have? They made a 5.5hp in '56 though...
And I run 24:1 in my 1950 Evinrude 7.5hp and it seems to work fine. I use full synthetic tcw3 though.
rockyrude
I stand corrected on the right ratio, I guess the real question was is this mechanic looking for business by reccommending changing to 50:1 with modern oils?
JB
I doubt it. He is probably satisfying a need to be knowledgable.. .unsuccessfully.
witenite0560
I can't find Chinewalker's article. Anyone got a link to it? Thanks.
Lil' Johnson
I have heard that the reason the older motors called for more oil in the mix is because they just used regular motor oil in them back then and when 2 stroke specific oils were formulated the ratio changed to 50:1. I don't claim to be an expert but it makes sense. That is why it is supposedly ok to run 50:1 in the older motors, because the newer oils are better, not because of any real differences in the engines themselves.
