cprince
- May 22, 2008
- 148
I am going to do this project in three stages due to necessity; I need the boat river worthy for the 10th of October for my little 4 day camping/walleye fishing trip on the Gatineau River using just my 50lb trust transom mount MinnKota.
Stage I (From September 21st to October 4th)
Remove all bondo-silicone and any other goop from the bellow water line. Stainless steel brush then sand.
Repair holes with Star Brite aluminum epoxy putty.
Sand.
Paint outside with Interprotect 2000E.
This will conclude Stage I.
Stage II (October 5th)
Sea Trials.
Ensure that the sucker doesn't leak!
If there are leaks - Gluvit on the inside- Apply on the 8th)
Stage III (April 2009)
Finish painting the entire boat.
Replace and reinforce transom to safely accommodate 15HP engine.
Fabricate removable casting deck for bow and stern.
Sept 21st
I went fishing today with my friends boat today and when I came home I decided to have a look at my new project. I flipped it over for the first time and had a good look at the bondo that was jammed along the keel. Gouged it out and scraped it away;
Found a nice hole.
QUESTION: Was it bondo? (Don't know if you can tell from this shot or not)
QUESTION: Is StarBrite good enough to fill this and expect it to safely last to next year? Should I use something in conjunction with this stuff?
There was also a piece of metal screwed in about 3 feet along the keel. Looked like an old shelving brace. Flat head screws mixed with Robertsons... guess which ones I like better! Quite worried about what I might find underneath... more gaping holes? Here it almost off:
Much to my surprise....
Silicon and screw holes!
WTF? I am going to assume that this was meant to protect the keel... what else would it be for?
Close up of the silicon and screw holes:
There is a bunch of silicon on many of the seams and rivets...
QUESTION: Wire brush on a drill get that silicon crap off? Or should I use a chemical stripper first then the brush? Just not certain if that stuff will just gum up the weel making it ineffective.
All in all, a lot less dammage than I thought there would be. I thought for sure that there would be a bunch of gapping holes under the metal strip. Feel like I dodged a bullet.
When I got the boat, the previous owner said that the boat leaked a fair bit; bail every hour rate of leakage. So far, I have not put it in the water, but I am reasonably confident that the drain plug was leaking as it was cloged and siliconed into place. I have since dug it out and purchese two new plugs for $5.
I might look into taking Thursday off to start, weather is supposed to be nice.
Sand.
Sea Trials.
Sept 21st
Found a nice hole.
