reelfishin
- Mar 19, 2007
- 3,050
I was wondering how strong is strong when it comes to a new boat's transom?
What got me wondering is a couple of things I ran across this weekend. One was a fairly new boat, less than a year old in which I noticed a fair amount of flex in the transom of an almost new glass boat with a 3 cylinder Yamaha installed. For some reason it didn't seem like it was all the way down and I was pushing and prodding at it to see why. What I noticed was movement in the transom itself. Not a lot, but movement. I could lift the motor and with the motor under my arm and in the locked 'UP' position, see visible movement in the transom. I could flex the transom about 1/4" or so overall when I was trying to get the motor to move on it's hinge. (It turned out to be defective new steer tube and bushing which was most likely damaged during installation of the cable and covered up).
Then yesterday morning I was at a marina/dealer getting parts and watched two guys fighting with an outboard on a small glass boat. Apparently they couldn't get to or were too lazy to go under the splash well to unbolt the two lower motor bolts and were flexing the motor up and down by hand apparently trying to snap the bolts. What finally gave was the whole transom, a load crack/pop sound could be heard as one guy lifted the motor as hard as he could under his arm against the transom. I was surprised that the transom gave way with far less force than I would have thought.
This made me double check my own boats, but there's no way I'd put that much force on my transom 'Just to see what happens'.
How much deflection and how much force is enough or too much?
I'm a pretty big guy and could feasibly also do damage if I tried.
The old test was always that a good transom will not move when you use the motor as leverage, but apparently that's not the case if you use enough force.
On my boats, I can put nearly all of my 290 lbs on the outdrive with no noticeable flex, but I never tried lifting the motor beyond it's limits.
A buddy was with me when we saw that display of mechanical genius, he went home and checked his new boat, and indeed, if you lift the motor and apply force, the transom will move almost a 1/2". No movement can be seen when pushing down or applying weight to the lower unit. We took that boat out for the first time two weeks ago, no transom movement is seen on the water and it is a brand new boat.
On all of the larger boats I've checked, there's little to no give in the transom, but on most smaller boats, even brand new, I can flex the transom to some extent fairly easily. We're talking new boats on the dealers lot.
On any of my boats which I have replaced the transom wood, I laminate a combination of wood and glass mat encased in epoxy, which makes for a very stiff transom, but even those will show some movement with enough force.
I did go out back and compare movement on an old Mako I have sitting at the shop, the boat and motor are junk so I could do as I pleased and not worry about ruining a good boat. I tilted the 1975 Johnson 3 cylinder all the way up and lifted, I could lift the boat off the trailer with no signs of transom flex, and that boats been sitting in the weather for years. I finally snapped the bracket off and the motor fell onto the splashwell with me holding the lower unit. It broke at the bracket hinge pin. Only the tilt guide and lock held the motor from dropping to the ground.
What it boils down to is how much force should a good transom tolerate? Even a solid transom will flex if enough force is applied. Every transom other than that Mako had some movement to some degree.
I'm not talking about a floppy rotted transom just movement. How much is normal?
