Bow Plane servicing
haskindm
Re: Bow Plane servicing
I thought only submarines had "Bow Planes". Does the forum have a section for submarines?;)
Dave52
Yep. Talking about the hyd tabs mounted on the transom. Boat is an 89 bayliner trophy. I hear the pumps but tabs dont move so I'm hopeful the reservoir needs servicing.
mtnrat
Likely just need ATF added. There are two lines on the reservoir. Fill to the lower one with the tabs down and to the upper when the tabs are up. Cycle a few times and add if needed.
Dave52
Thanks for the advise. Seems the consensus is ATF so we'll go ahead with that and hope for the best that its a service issue rather then a bad pump.
