mysticgman
- Jun 19, 2007
- 14
I have a 1957 Johnson 18hp fde-11 Model outboard. I've been working on it for a while now & having starting problems, possible carb. This is what I have done: new plugs,new carb kit, cleaned carb very thoroughly, float is horizontal when inverted, needles have been set {3/4 out, 1 1/2 out}, checkpoints are good and properly gapped. When trying to start, it will sneeze once or twice and then that is it! When I push the choke in, gas gushes out in front of carb almost as if it is allowing too much fuel into the carb. Motor has great compression & excellent spark. So why isn't it starting to burn off the excess gas coming into the carb?
Also, I have heard that I should replace the coils is this true? Do they go bad easily? If so, where is the least expensive place to get new coils?
Please help I'm in dire need of "GOING FISHING" !!
