Hello all,
I took my boat out this morning and ran into some trouble. It over heated due to a clogged water intake. I shut it down after it started smoking but before it seized up.
Got it home and replaced the plugs and it starts up with help of a little staring fluid.
My problem is that I am not getting good flow though the water inlet. The clog is gone (I think..water flows though the inlet out the "pee" tube with it has the water muffs on with the garden hose attached.) I also blew compressed air though the system and it seems to be fine. When I started it up (with the muffs and water on) the pressure and volume did not increase when I placed the motor in gear and gave it a little gas.
So I started to poke around and found a round cover on the front side of the head just above the top spark plug. I removed the 3 bolts holding it on and found what I think it either a pump or a thermostat. Either way it is broken and have to find a new one.
So my questions are:
1) Dose this year and model have a water pump and a thermostat? (model # J15 ECCS)
2) Were can I get parts for this year and model?
Thanks
Grif
Thanks
Grif
