Fishermark
- Oct 19, 2003
- 5,627
Sorry in advance for the long post... Hang in there to the end and see if you can give me any direction!
My dad called me this morning with a problem he was having on his boat. First a little background.... This is an early 70's 165 Mercruiser - straight six with an aftermarket alpha clone outdrive. This is the same engine I rebuilt for him last year. More details on the engine, etc are here:
http://forums.iboats.com/showthread.php?t=236240
Anyway, he said after coming in from fishing last week he went to flush the engine when he returned and the starter just clicked or chattered. He suspected maybe the battery cables were corroded, so he took them off. When he took the cable off the starter, he broke the solenoid. He took the starter off and took it to the local shop, they put a new solenoid on for him. When he went to hook the wires back up he got a big spark every time he tried connecting the wires. At this point he calls me.
Long story short... or at least shorter.... here's what I have done and discovered so far:
I began unhooking the various wires and plugs, then reinstalling them one at a time to see what was causing the spark - or short. Narrowed it down to the alternator. With everything else connected, EXCEPT the big red wire at the back of the alternator, there is no problem. When we try to connect the wire to the alternator there is a big spark.
Okay I think to myself: Problem solved. That would even explain why the battery was down after running the boat for the day. Figure the alternator is shorted out inside somehow. We will be taking that in for testing and rebuilding or replacing.
Here's where it gets weird....
With the alternator removed and the big wire at the back completely disconnected, I tried starting the engine to flush it;. Wouldn't start at all - starter turns, engine spins fine, just does not start. We notice smoke coming out of the distributor.
Took the cap off and the Pertronix Ignitor II module is burned and melted. Not good.
Put the points back in and try to start the engine. Same thing... EVEN TO THE SMOKE FROM THE DISTRIBUTOR! Remove cap again - points are so hot that I burn my finger when I touch them. (This is only after five to ten seconds of trying to start the engine).
Well, the only thing that the points are connected to of course is the coil. It is a Pertronix Flamethrower coil. I put a different coil on and let the points cool off. Engine starts right up.
What the...!
He wants to put a new Pertronix unit in - which I'm glad to do... BUT... I need to know what caused what? Did the alternator cause the coil program? Or visa versa? It can't be a coincidence. Anyone shed any light on this problem?
What the...!
