I want to add a couple bunkers to my trailer. The boat is a 16 ft fiberglass bowrider and the existing bunkers are only 5 feet long. So basically the forward 11 feet of the boat is being supported by the front bow roller and the front keel roller. I plan on welding on some plates to the trailer crossmembers to bolt the additional bunkers to. While I'm a it, I might as well change the existing bunker carpet. What would be the best way to raise the boat off the trailer in order to do this work. I suppose only raising one side and working one side at a time would be safest. All I have are a few jack stands and a floor jack. Can I use the floor jack if I put a 2X6 between the jack and the boat? Where on the bottom of the boat is the best place to put the jack? I don't want to start raising the boat and have the jack go right through the bottom. I'm also afraid the jack will slip and the boat will come crashing down.
