defaultech
- Oct 7, 2008
- 3
I have a 73 model johnson 25 hp. I have kitted the carb, set points, replaced fuel line, put new gas in, checked for air leaks, fuel leaks, replaced fuel pump.You name it and ive done it. Darn thing runs well except for wide open or near wide open. It runs for just a bit then falls on its face, up and down. But, if i pump the bulb it just flies like mad, as long as you keep the bulb pressured. Is there anything internal that would cause fuel pump to not pump? Engine pressure? Im just confused, i have replaced everything and i know its starving for fuel at high speeds. What else could it be. Im to the point of putting an electric pump on the crazy thing
