Have a 2006 Mercury 90 hp, (3 cyl) carburetors / not fuel injected. Have less than 50 hours on the motor. The engine will run fine on some days and on others, will start off fine, but will cut out sometimes at low rpm's, but usually when putting it on plane. When it cuts, it feels like someone turned the key off, as it will drop from 44mph to 30mph when it happens, and I can't get it to accellerate past 30 or so mph. I have to idle the motor down and back up again to run it again, but it usually will cut out again. Had it in the shop for part of the summer and the shop did see what it was doing but could not figure it out. They tested the CDM grounds which were fine, I guess. The number 1 cylinder was the one with the problems, when it was acting up for the shop. Plugs were good and so was compression.
