I have a '99 Mercury 60 hp 2 stroke and I think the trim is giving up. Here are the symptoms:
When I am under power and try to trim the motor up in order to clear an underwater obstacle, the motor trims up a ways and then slowly slides back down ( but not all the way down). When the boat is not under power, I am able to trim the motor all the way up, so I am assuming that the movement of the prop is "pulling" the motor back down into the water.
Is this a way of the motor preventing itself from raising to a point where the water pump would be unable to pickup water?
I have checked the trim oil level and it is up to the screw as it should be.
I have also tried pulling the motor down when the boat it on the trailer, but am unable to get it to behave as it does under power.
Any suggestions would be great!
Thanks,
Andrew
Thanks,
Andrew
